Originally Posted by Fudgie ....Can anyone tell me what I'm doing wrong, so that I can view on normal DVD players....
Martin |
Its very hard to say
This sort of thing generally only happens if you are ( inadvertently) making your DVD videos as a Data DVD with video files on them . It may also be related to questionable DVD recordable Media which may be PC friendly but the DVD players are more fussy about
If you are using DVDA you are obviously making DVD videos.
Do the discs play on the PC
with menus? If not the authoring process might be wrong but the video files are still present on disc so they play on the PC ,
1 or 2 suggestions to find out why :
1:Try to make a DVD folder and then use Nero to make the DVD video
2:Output from Vegas as mpeg2 then make a DVD video in Nero vision
If the first plays on all: there is an issue with burn settings in DVDA : If the second plays on all , DVDA settings need to be looked at again. If
both will play on PC but not Settop DVD player, the Media is most likely at fault: try using something else
