18-12-2006, 4:39 PM
#1 (permalink)
| | Member
Thanks: Gave 1, Got 3 | HDR-HC3 Spare Battery
I'm looking to buy a spare battery for a Sony HC3.
Having a quick look on the forums I notice that some are not compatible, especially the none Sony ones.
Can anyone recommend or let me know what they have.
19-12-2006, 8:42 AM
#3 (permalink)
| | Senior Member
Thanks: Gave 27, Got 61 | Re: HDR-HC3 Spare Battery Quote:
Originally Posted by Accylad | how old's your HC3 though?
apparently the ones bought recently don't work with non-Sony batteries
Maff
19-12-2006, 10:01 AM
#4 (permalink)
| | Veteran Member
Thanks: Gave 90, Got 749 | Re: HDR-HC3 Spare Battery
I'm pretty sure all the HC3s have some check for genuine Sony batteries. My HC1 which pre-dates the first HC3 models checks for genuine Sony batteries as well.
What has happened is the generic battery manufacturers had figured out how to fool the camcorders... so when it checks for a genuine battery, the battery appears to the camcorder to be genuine even though it isn't. This is why some generic batteries work and some do not.
To make it more confusing, I believe the later HC3 models added some extra logic to do a more detailed check - so now some batteries which may have worked on earlier HC3 models no longer work. But I assume the generic battery makers are fighting back and enhancing the batteries so they will be accepted by the newer HC3s...
The net result of all of this is if you buy a generic battery it may or may not work on your HC3, even if it works for other HC3 users. Make sure you can return the battery easily if it doesn't work.
Mark
19-12-2006, 10:06 AM
#5 (permalink)
| | Senior Member
Thanks: Gave 120, Got 110 | Re: HDR-HC3 Spare Battery Quote:
Originally Posted by mmace how old's your HC3 though?
apparently the ones bought recently don't work with non-Sony batteries | Had it for about 6 weeks - the battery has given no problems at all
19-12-2006, 11:14 AM
#6 (permalink)
| | Member
Thanks: Gave 1, Got 3 | Re: HDR-HC3 Spare Battery Quote:
Originally Posted by Accylad | Thanks.
Is it a genuine Sony battery?
How long does is last on a single charge?
19-12-2006, 12:08 PM
#7 (permalink)
| | Senior Member
How long does is last on a single charge? | Hi - No its not a Sony battery - it doesn't have a brand name on it.
Just put it in my camera and it reports 220 mins remaining
19-12-2006, 1:45 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 48, Got 85 | Re: HDR-HC3 Spare Battery
It's an extra hassle risking that you may have to send it back, but one worth taking IMO. It's criminal that Sony spend time and money changing their product so that they can rip us off with expensive batteries, and I'll do what I can to get around it.
__________________ 50" Pio MXE1, SkyHD, SDI DV89, Lum HDP/SDI, Merid 561, Bluesky 6.5s & 5s, Velodyne SPL 1200 II, 360. Sq box II x5, TAG DAC 20, Exposure XIX, Mackie HR624, Exp 2010S, Arcam A75+, Dyn 42W x4, AR A-06 + Bthrm speakers.Sony HDR HC3, Nikon D70.
Car: 80Gb Ipod, AlpineIDAX001, Blaupunkt & Kenwood spk |
20-12-2006, 8:27 AM
#9 (permalink)
| | Senior Member
well, the one I ordered from eBay came yesterday, put it in my brand new HC3 and charged it, said it had 3 hours battery life, stated recording and it lasted just under 3 hours!
Maff
20-12-2006, 12:13 PM
#10 (permalink)
| | Member
Originally Posted by mmace well, the one I ordered from eBay came yesterday, put it in my brand new HC3 and charged it, said it had 3 hours battery life, stated recording and it lasted just under 3 hours! | Which seller did you buy it from on e Bay and how much did you pay, if you don't mind me asking?
20-12-2006, 1:35 PM
#11 (permalink)
| | Senior Member
Originally Posted by PMW Which seller did you buy it from on e Bay and how much did you pay, if you don't mind me asking? | I paid £18.39 including delivery from a seller called lmb_direct - http://stores.ebay.co.uk/LMB-Direct
Not sure if I'd recommend them, I paid for next day delivery but it took a week to get here!
no probs apart from that though
it appears as though they don't have any at the moment anyway (although there were 3 more available when I bought mine and the auction timed out)
Maff
