Originally Posted by cj550 ......
But I've noticed when I use Pinnacle Studio 9 to capture the footage but when I come to make the movie it asks for the tapes to be put back in and it plays them again? has it not already captured the footage? cheers |
What has happened is that you have captured the footage at preview quality and have edited "by proxy"
So the edits are noted and stored but have not been applied to the video footage captured at its best quality
As such the program needs to
recapture the best quality video and then apply the edits to it at the stage when it needs to make the DVD as it doesn't want to make a DVD from the previously captured lower quality "preview quality" material
This helps if you have limited space to capture footage as your 90 min will take up just over 18Gb of space, and the render files a bit more. all this can certainly be reclaimed after the project
I've only used it once ( to try it out) and didn't bother after wards as it only adds one more step to the process and can be a serious PITA if you capture from more than one tape
The way to avoid this is to capture at full DV quality in the first place
