Originally Posted by Lerche As cj550 was asking “can anyone tell me what I need to do to get the best reproduction of my footage onto a 4.7gb DVD?” I’m in the same boat as far as this question is concerned. I’ll capture in DV AVI, edit and then save as video file (AVI) using Ulead MediaStudio Pro 8. I then use Movie Factory 4 to author the video file and burn to DVD. If the video is less that 1hr, no problems, it will burn in best PQ. However, if the video is more than 1hr it will down grade the PQ to fit onto the disk, BUT NOT USE ALL OF THE DISK??? i.e. 1.5hrs will only use 75% of the DVD. I’ve tried all kind of settings to make it use the entire disk, but so far with no result. Is there a DVD authoring software that has a “fit to disk” button that you would recommend? Thanks |
The Mpeg encoding software use a constant bitrate or variable encoding bitrate to encode and end up with whatever space they use.
Set top DVD recorders have the 1 hr , 2 hr, 4 hr modes and the flexible modes . They also just use variable bit rate encoding but just vary the minimum and maximum ranges depending on mode
The DVD authoring software use simple methods to compute encoding bitrate based on the time .
Only by using thier advanced methods or custom settings can you get a 1.5 hr video to try and fill up more space than 75% of the disc.
Other space saving strategies are use of ac3 rather than PCM ( or LPCM) audio or using lower sampling audio frequencies if using PCM.
It may be that by filling up more space on the DVD you may not get an appreciable gain in PQ and risk using up some of the "overheads" that the disc authoring and writing process need, leading to an unreliable "burn"
For instance, even if you had less than one hrs worth of video it would be unwise to push the mpeg encoding rate to maximum in order to fill up the disc as this might produce a DVD that quite a few players would choke on !
If you really want explore just how much you can wring out of a 90 min video without losing much disc space, a standalone encoder like Canopus Procoder Express ( being with drawn) or Canopus Procoder 2 which has lots of settings to tweak is more suitable than a DVD authoring application
In addition to MF5 I also use MovieWorkshop2 ( amongst others) , seldom bother with its advanced settings but sometimes when I do, I get a warning of potential disc incompatibility and just leave well alone
