Ok I have an NVGS 250.
I do a lot of downhill mountain biking. Now I want to get some footage which would be good of some of the routes from the riders position
I have this and this - see piccy
http://img103.imageshack.us/img103/9279/p1000114kz5.jpg
whats the best way to use this with the camera, the only way I can think so far is to use a good amount of duct tape and foam or something similar to give it a bit of cushion and tape it to the top of my helmet, I'm not that bothered about the paint coming off etc, just the longivity of the camera as long as I I dont come a cropper! I've looked into various helmet cameras without spending the earth and after contacting vaious people and checking out the quality they are rubbish. I'll also use it hand held sometimes but thats kinda irrelivant to the topic.
this is a short video of a place I sometimes go, as you can see the quality is rubbish about the same I've been sent uncompressed ( the route is fairly tame compared with some)
http://www.youtube.com/watch?v=szRu38GsCkw they vary slightly, but not much better, so i guessed a good 3ccd cam with a good lense would do the job. whats your general opinion?
