Originally Posted by choddo2006 The only thing Pinnacle renders as you go along is transitions & filters. It still takes ages to re-encode the whole movie afterwards. |
It is only transitions and filters , effects ( and trimmed footage on the timeline) that need rendering, not intact video.
Rendering and encoding are different processes even though they are often made to appear seamless by software.
A bit more detail to clear the air:
"Pinnacle" seems to be loosely used here Studio is only one ( and the "baby" ) of thier products.
Up till being bought by AVID, Liquid 7 was Pinnacle Liquid Edition 6.1. Avid 7 is an upgraded LE6.1
Background rendering is obviously better implemented in Liquid, as any action (including complex 2d/3d keyframed effects ) performed during editing is rendered "on the fly".
It does use a bit of CPU and GPU power but it works very well.
While its' happening you can tell if you will get 25 fps timeline preview or less.
If you get 25fps you can carry on working
This may not happen quite as well in
Studio 10 (which uses part of Liquids software "engine") to do what it calls "Intelligent rendering" though the principle is similar
Encoding to mpeg can only happen after the edit has finished. This commits the editing and any further editing is not expected on that particular outputted video file.
Reencoding only happens if you used mpeg in the first place, or the timeline has video from various formats needing to be intergrated to form one outputted format.
If for instance you "fuse sequence" from DV AVI material in Liquid (6.1 ) or export as AVI in ver 7 ( in which case you are keeping the edit as AVI) it is amazingly quick to export as no encoding and no further rendering needs to be done.
It just "compiles" it and combines the video and audio track . It is also faster to produce an elementary stream mpeg where the audio and video are separated
If you find Pinnacle Studios encoding slow, you can export as an AVI in "make movie" and use a faster external encoder like Canopus Procoder Express to make an mpeg ( or whatever video format you want the video to be).
You may find yourself prefering its better encoding quality too.
In the past I did that a lot when Studio would crash during "make movie": Studio crashed less often when making an AVI as opposed to mpeg.
The disadvantage of that is that If you wish to use its DVD authoring later , it may still reencode. This will not happen with say Ulead MovieFactory if it is satisfied that the mpegs are DVD compliant.
