Honeymoon Video Help Req'd!
Old 01-10-2006, 8:10 AM   #1
Illustrious Member
Azzin's Avatar
54,564, Level: 57
Points: 54,564, Level: 57 Points: 54,564, Level: 57 Points: 54,564, Level: 57
Activity: 57.8%
Activity: 57.8% Activity: 57.8% Activity: 57.8%
Thanks: Gave 4,008, Got 1,323
Exclamation Honeymoon Video Help Req'd!
Hi all,
I'm having a mare trying to watch our honeymoon video.
We've got a Sony DCR-DVD755 camcorder that records straight to 8cm DVDs.
We have 3 cds of our honeymoon, but only one of the disks is readable in the DVD player (Snazio 1350)
The one that is readable plays beautifully-full screen/nice & clear, etc.
The other 2 just sit there while the Snaz says "Reading Disk"
The only difference between the disks is that the disk that plays fine is a DVD+ R & the two that won;t read are - Rs.
I have finalised the disks in the camcorder, & can play them on my PC using Power DVD, I can even stream them to my TV in the living room by sharing the CD Rom drives in Snazio software (they come out in 4:3 though )
This is a brand new camcorder that was bought for our honeymoon, & I wanted to be able to record things then play them straight away (or take them to someone's house & use their DVD player)
Surely that's not too much to ask from a DVD camcorder?
All help & advice gratefully received!
Cheers.
PS-The recordings were made in VR mode if that's any help?
[Edit]-All 3 disks were created in VR Mode, but the only one I can put straight into the DVD player & watch is the DVD+R.
Old 01-10-2006, 9:11 AM   #2
jomike's Avatar
9,090, Level: 22
Points: 9,090, Level: 22 Points: 9,090, Level: 22 Points: 9,090, Level: 22
Thanks: Gave 461, Got 377
Re: Honeymoon Video Help Req'd!
The donly difference between the disks is that the disk that plays fine is a DVD+ R & the two that won;t read are - Rs.
VR mode is only for editing in the camcorder when you are using -RW discs. Most DVD players will not play discs recorded in VR mode. If you want to play the discs in most DVD players you must record in video mode. Have a look in your manual. There should be a table explaining the differences between VR and video mode, and -R, -RW and + RW formats.
All is not lost however. What you can do now is:
1. Connect the camcorder to a DVD recorder using the A/V cable and record the footage onto a 12cm DVD.
2. Transfer the footage from the 8cm DVD to your PC and using a DVD authoring program, burn a 12cm DVD.
Both ways should give you a DVD that will play on most DVD players, and you can put all of the footage from the 3 8cm DVDs onto 1 12cm DVD.
In future, record in video mode and your DVDs should play on the DVD player after finalising.
Regards, Mike
Azzin (02-10-2006)
Old 01-10-2006, 9:14 AM   #3
Illustrious Member
Azzin's Avatar
54,564, Level: 57
Activity: 57.8%
Regards, Mike
Excellent, thanks Mike!
I don't have a DVD Recorder, so I would need to transfer it using option 2 above-do you have any recommendations for software?
Many thanks-makes much more sense now!
Old 01-10-2006, 9:35 AM   #4
jomike's Avatar
9,090, Level: 22
There are some free utilities such as DVD Shrink that will do this. It will require some reading of the tutorial.
http://www.videohelp.com/guides.php?...elect=6;65#897
Nero Vision, TMPGEnc DVD Author, Ulead Movie Factory (amongst others) will also do what you want, but arn't free. Most do give a free 30 day trial.
If you want to edit your movies (cut out bits, add titles, add soundtrack etc), I would recommend Ulead VideoStudio 10+. This also has a 30 day free trial.
Regards, Mike
Azzin (01-10-2006)
Old 01-10-2006, 3:46 PM   #5
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Regards, Mike
DVD shrink is free and easy to use: Youll be up and running in no time.Still the link has a guide
UleadMoviefactory5 is not free.
However it doesnt cost much It can do more than Nero vision and is both cheaper than and easier to use than TMPGencDVD Author
Azzin (01-10-2006)
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 13th at 12:30pm. Prices include delivery.
[IMG] code is Off
