| Re: Panasonic SDR-S150
Ive had no luck searching for a useful review of this camera. Hopefully you can answer a few questions??
How's the camera?
Which SD card did you buy, does it work okay?
Did you own a mini-dv camcorder before? what's the quality like on comparison?
Can you steady your picture, as it's so small?
How did you get on with editing on the pc, compared to a mini dv tape?
I heard each time you pause the camera it creates a new file, I hope you can play them all in one sequence when attached to a tv?
I was planning to backup on my pc to an external USB drive, what do you do?
How long does the battery last?
What's it like in low light when compared to a standard "up to date" camcorder?
In the best quality mode how long would you get on the 2GB Sd card?
Any other issues?
Thanks in advance,
Regards,
Jez.
