Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Latest popular product pricesPowered by
Sony DCR-SR37E 60GB
Panasonic HDC-SD10
Sanyo Xacti VPC-CG10
Sony HDR-XR200VE 120GB
Sony DCR-SR37E 60GB
Panasonic HDC-SD10
Canon Legria FS200
Canon Elura 60
Panasonic HDC-SD200
Sony DCR-DVD150E
Panasonic SDR-S26
Panasonic HDC-TM10
 More...Prices updated March 21st at 7:30pm and include delivery.
Thread Thread Starter Forum Replies Last Post
Mordaunt Short Architect range CITY_MANC Speakers 3 29-09-2006 12:00 PM
Sony Vegas 6.0d and DVD Architect 3.0 Help needed. nizam Camcorders and Video Editing 13 07-07-2006 11:01 AM
Building Architect BiggieBig General Chat 16 21-11-2005 12:20 AM
DVD Architect problems. BadAss Camcorders and Video Editing 4 26-11-2004 3:38 PM
Old 28-09-2006, 8:16 AM   #1 (permalink)
Thanks: Gave 5, Got 9
Smile DVD Architect 4 Help needed
All, a post after a long time, i try to make a DVD with the help of DVD Architect 4 every time i try to click burn the current project it says there is not enough space in the folder you can only use an empty one or the one already prepared to , so i made an empty folder in my My Documents, but still the same window poping up saying there is not enough space in the folder, How can i overcome this, also how can i fit this 8.9 Gig program in to one disk , Is there any way i can split in to two disk with the help of DVD Architect 4.Please help me
Rgds
Nizam
nizam is offline   Reply With Quote
Old 28-09-2006, 8:50 AM   #2 (permalink)
redsox_mark's Avatar
Thanks: Gave 90, Got 749
Re: DVD Architect 4 Help needed
There are 2 steps in DVDA:
1. Prepare: This creates the DVD file structure (VIDEO_TS folder with .VOB files). In doing this DVDA will warn you if it thinks your video is too large to fit on a DVD, but it will still let you do it. If it is saying there is not enough space in the folder, that means there is not enough space on your hard disc. The Make DVD window will show you the "free space in selected folder". Clean up your hard drive, or select a different drive to use for the prepare.
2. Burn: This actually burns the DVD. If you are using a single layer disc, it needs to be less than 4.7 GB. If you are using a dual-layer disc then it can be 9.4 GB, and DVDA can add the layer break for you. But if you want to split it over 2 different single layer discs, you will need to author this as 2 separate discs. I.e. take your main movie and split it into 2 parts in Vegas. Then author a disc in DVDA for part 1, and another for part 2.
Note when you select "Make DVD" and select "Burn", it gives you a choice to burn a folder you already prepared, or to do the prepare step and then immediately burn.
Of course the other thing you can do is change the bitrate to make your whole movie fit on a single 4.7 GB disc, but this impacts the quality. How much of an impact depends on how long it is (and thus the bitrate required).
Mark
redsox_mark is offline   Reply With Quote
Old 28-09-2006, 9:08 AM   #3 (permalink)
Smile Re: DVD Architect 4 Help needed
Thanks for the info, but how do i split it in to two in vegas, i am using vegas 7.I dont want to loose quality so i better split in to two in vegas an author it saperately.Also if i use an external hard drive can i overcome the issue of no space in the folder , how do i connect an external hard drive in to usb port?
Rgds
Nizam
Old 28-09-2006, 10:21 AM   #4 (permalink)
You need to render out 2 different videos in Vegas – part 1 and part 2. A couple of ways to do this, both involving selecting a region:
1. (Keep it one .veg file): Click and drag above the timeline to select the region for the first half of the movie. Render this out to .mpeg and .ac3, making sure to tick the box saying “render loop region only”. Now do the same selecting the second half of the movie (perhaps with a few seconds overlap), and render out part 2.
2. (2 .veg files): As option 1, but this time make 2 copies of your Vegas project (.veg file). In one of these, delete the 2nd half of the movie (easiest way is to select the region and delete), so all you have is part 1. Render this out. In the other file, delete the first half of the movie, so all you have is part 2. Render this out.
An external USB drive will come with a USB cable, you simply follow the installation instructions. And yes, if you are out of space on your system drive this will solve your problem.
Mark
architect, dvd, needed
[IMG] code is Off
Copyright © 2000-2010 M2N E. & O. E.
