| Re: How do I record DVD from NTSC camcorder?
I believe some DVD recorders will record PAL60, and some even NTSC (some Pioneer models if I recall correctly). So one option would be to replace your DVD recorder with one which accepts one or both of these... (you could ask on the DVD recorders forum).
Or, you could capture the NTSC to a PC and create a DVD from there. But as it is an analogue camcorder that also requires hardware to do the capture. Then either converting to PAL in software, or you could keep it NTSC as most PAL DVD players will play a NTSC disc.
