record from camera onto dvd unit - can i edit?
Old 02-07-2006, 5:28 PM   #1
5,314, Level: 17
Points: 5,314, Level: 17 Points: 5,314, Level: 17 Points: 5,314, Level: 17
hello
have a bullet cam that i would like to record into the AV input of a dvd recorder unit (some typical domestic one).
would like to just keep recording for probably an hour, but then would wish to be able to put dvd into computer (premiere 6 editing software) and be able to cut and chop so as to get edited end result.
Q: will recordings from a domestic dvd (via the AV in) be able to be recognised by computer in order to edit??
thanks
Old 02-07-2006, 7:40 PM   #2
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
Yes - you can take a DVD created by a DVD recorder (as long as it is finalised) - providing the PC drive accepts the disc type (e.g. if you use DVD-RAM discs on the DVD recorder, you need a PC drive which is compatible... many are not. If you use DVD-R discs they are generally compatible with all drives. It doesn't make any difference if the DVD recording came from the AV-in or if it was recorded off TV.
I don't use Premiere 6, but I'm sure it can handle the files. You may have to rename from from .VOB to .mpg. With the software I use (Vegas 6) you can either do that, or there is a command to "import camcorder disc", which works for discs made in a DVD recorder as well.
Old 02-07-2006, 10:51 PM   #3
47,154, Level: 53
Points: 47,154, Level: 53 Points: 47,154, Level: 53 Points: 47,154, Level: 53
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 1,052, Got 2,970
Im not very sure Premiere 6 Can import Mpeg2 files ( 6.5 can) ( which is what the VOB file in a DVD are ) but certainly its simpler sibling Abobe Premiere Elements can
Even so , any software which does not natively edit mpeg file ( eg AP6.5) has the potential of resulting in poorer quality video if extensively edited due to reencoding several times before the finished product
There are better editors ( if less accomplished than Adobe Premiere ™, for mpeg editing)
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 13th at 9:30pm. Prices include delivery.
[IMG] code is Off
