Is there any way to cut a .TS HI def stream
Old 19-06-2006, 3:14 PM   #1
3,872, Level: 14
Points: 3,872, Level: 14 Points: 3,872, Level: 14 Points: 3,872, Level: 14
Thanks: Gave 15, Got 24
I have a 13gb 1080i hi def video in .ts transport stream format. I want to put it on DVD. How can I chop/cut this file into 4.35gb chunks?
any ideas?
Old 19-06-2006, 3:29 PM   #2
Goose74's Avatar
6,359, Level: 19
Points: 6,359, Level: 19 Points: 6,359, Level: 19 Points: 6,359, Level: 19
Thanks: Gave 69, Got 12
HDTVtoMPEG2 is your answer!!
Old 19-06-2006, 3:57 PM   #3
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
Goose74,
I just tried HDTVtoMPEG2 on a HDV m2t stream, but it didn't work for me. It seemed to run, but the output file was only 3 KB in size and didn't play. Are you sure this works for HDV from a camcorder (which I assume is what "poggs" is asking for), as opposed to a HDTV stream? This software was written long before the HDV standard was even created..
Mark
Old 19-06-2006, 4:52 PM   #4
Goose74's Avatar
6,359, Level: 19
ah apologies - I have not tested it with HDV - I guess I wrong assumed it was mpeg2 TS hdtv stuff. Would total commander work?
Old 20-06-2006, 7:58 PM   #5
andypandy's Avatar
9,125, Level: 22
Points: 9,125, Level: 22 Points: 9,125, Level: 22 Points: 9,125, Level: 22
Thanks: Gave 13, Got 11
aren't you seriously downgrading the quality, by doing that ?
HD to normal dvd.
Old 20-06-2006, 8:15 PM   #6
22,297, Level: 36
If you downres to SD for DVD video, yes. But the question was about taking the native HDV file and splitting it up (to put 20 mins or so on a DVD).
I think Womble can probably do this.. but that costs (and I don't have it to be sure).
Mark
Old 21-06-2006, 6:01 AM   #7
vonhosen's Avatar
5,917, Level: 18
Points: 5,917, Level: 18 Points: 5,917, Level: 18 Points: 5,917, Level: 18
Thanks: Gave 0, Got 17
Mark
30 day free trial if you want to try though
Old 21-06-2006, 6:09 AM   #8
cwick's Avatar
7,580, Level: 20
Points: 7,580, Level: 20 Points: 7,580, Level: 20 Points: 7,580, Level: 20
Thanks: Gave 45, Got 98
Can't use just use zip or winrar to break it into chunks ?
Old 21-06-2006, 7:23 AM   #9
Illustrious Member
dejongj's Avatar
29,883, Level: 42
Points: 29,883, Level: 42 Points: 29,883, Level: 42 Points: 29,883, Level: 42
Activity: 62.9%
Activity: 62.9% Activity: 62.9% Activity: 62.9%
Thanks: Gave 1,012, Got 1,590
Yes winrar can do that without compression...And you can also create some parity files which is good if you archive and one of your files get corrupted...Alternatively there is also a utility called tsmerge.....which funnily enough can also split
Old 21-06-2006, 9:07 AM   #10
22,297, Level: 36
Looks like WinZip 10.0 Pro on Windows XP can also split a large file over multiple DVDs.. so I assume this would also work for a ts file. If it is just for archiving this would work....
ts merge sounds interesting... I found some references to it with a Google search but couldn't find a working link to the software...
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 2:30pm. Prices include delivery.
[IMG] code is Off
