Help using Vegas 6 and 16:9 project
Old 16-06-2006, 4:47 PM   #1
5,507, Level: 17
Points: 5,507, Level: 17 Points: 5,507, Level: 17 Points: 5,507, Level: 17
Have filmed some footage on my HC1 and captured it to Vegas in dv in 16:9 whats settings do i need to make the new project and to render out at if i want to render out to MPEG 2 NTSC but in 16:9 ?
cheers
Old 16-06-2006, 4:57 PM   #2
redsox_mark's Avatar
22,297, Level: 36
Points: 22,297, Level: 36 Points: 22,297, Level: 36 Points: 22,297, Level: 36
Thanks: Gave 90, Got 749
You want your project properties generally to match the media, so I assume this is PAL DV you captured, so you would set the project properties to "PAL DV Widescreen (720x576, 25.000 fps)".
If you want to render to NTSC MPEG2 for DVD, then render to file type MPEG-2, template "DVD Architect NTSC Widescreen video stream". As you are rescaling (going from 720x576 to 720x480), you will get better results if you select the video rendering quality (in the "custom" screen) to "best).
As you may know, you also need to separatly render the audio.
Mark
Old 16-06-2006, 5:33 PM   #3
5,507, Level: 17
cheers mark, i use REEL dvd for authoring so yeh will do the NTSC and the AC3 streams seperate. So to render in 16:9 i select widescreen and to render into 4:3 i use the normal dv setting is that correct?
cheers
Old 16-06-2006, 6:29 PM   #4
22,297, Level: 36
Yes, that's right. For widescreen use the widescreen template, for 4:3 the one which doesn't say widescreen (e.g DVD Architect PAL video stream). These templates have the PAR (Pixel Aspect Ratio) correctly set for widescreen (or 4:3).
Mark
Old 16-06-2006, 6:46 PM   #5
5,507, Level: 17
ok might seam a silly question but is widescreen the same as 16:9 ?
Old 16-06-2006, 6:49 PM   #6
22,297, Level: 36
Yes. Widescreen = 16:9.
Mark
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
4 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 11th at 9:30am. Prices include delivery.
[IMG] code is Off
