Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 21st at 10:30pm and include delivery.
Old 13-06-2006, 9:38 PM   #1 (permalink)
jumpman23's Avatar
Thanks: Gave 1, Got 26
Help choosing a microphone
Hello,
I have had my HC1E since november '05, and would now like to purchase a suitable external mic. I have heard heaps of praise for the Rode Videomic, as well as certain sennheiser and audio technica products. Also with the rode stereo videomic having been announced for ages (still no word on release), i don't know whether i should wait or go ahead and get a mic now.
The main use will be for recording live functions, with music and speeches mixed in, priority given to music.
I currently use sony's HQ1 mic and find it lacking in low end frequencies with an overall flat sound.
There seems to be a lot to choose from and would like to know what type of mic i need (eg shotgun, cardioid, omni, stereo) for best accurately reproducing performances.
i dont want to have to use external power if it can be helped
i don't mind spending a bit if it is worth it, but nothing to expensive - up to £350 at the most.
jumpman23 is offline   Reply With Quote
Old 14-06-2006, 6:47 AM   #2 (permalink)
hot-fuzz's Avatar
Thanks: Gave 229, Got 279
Here is a list of Sony mics for you :
http://www.sony.co.uk/view/ShowProdu...CC+Microphones
The bluetooth ECM-HW1 is meant to be very good :
but might be a little low budget for you (~£150)
hot-fuzz is offline   Reply With Quote
Old 14-06-2006, 4:07 PM   #3 (permalink)
toadoftoadhall's Avatar
Thanks: Gave 2, Got 25
I guess it depends on what sound you want to record. I have different mics for different things, but nearly always use a stereo mic for general recording. The Rode mic everyone likes is mono.
Dont forget, if you are recording something at a distance, but want better sound, you can always use a mic on a long cable if possible, or radio mic.
toad
toadoftoadhall is offline   Reply With Quote
Old 14-06-2006, 8:51 PM   #4 (permalink)
jumpman23's Avatar
Thanks for the responses - i already have a sony mic and don't want another one of them, something more upmarket. sounds like a decent stereo mic is the way to go. i know rode videomic is mono, but a stereo version is due to be released:
http://www.rode.com.au/?pagename=Med...duct_name=NULL
no news as to when though
question is shall i wait or is there a specific alternative out there eg sennheiser mke300d, or a decent stereo mic
thanks
Old 16-06-2006, 6:49 PM   #5 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 463
The Rode Videomic may be mono but it does have a stereo jack on the lead so it will record audio to both channels. If recording a speech then mono is all you need, and even for music with the close proximity of both mics you wont get much stereo separation on the sound anyway - for this you will need two off camera mics placed a good few feet apart.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
choosing, microphone
[IMG] code is Off
