Could be a multitude of things .Have you tried the software [ulead] before on another project ?? did it work then ?? What's the spec of your PC?? . Has it got internet access , meaning are you running anti-virus software ?? Have you got anti-spyware software on your PC?? . The reason's : if you have a virus your PC may grind to a halt . If you have some sort of spyware on your PC ,it will slow the PC down and be using up resources .Anti-virus programs are using up resources while scanning system files .Have you a fragmented drive ?? . Scan your PC, first using a anti-virus program then scan for spyware , if all clear disable your anti-virus proggy and de-frag your PC.This should speed thing up abit .Then try using Ulead .If still the same , it could be a software related problem or even a hardware related problem .Does your DVD drive write to other disks ?? try making a audio disk to see that works . As said , it could be anything , try to elimenate as much as possible.
