Originally Posted by laser Yes, that's right.
I've left it switched on once and captured footage to the PC as DV rather high def.
The only other things I can think off is there is a Sharpness option on the HC1E, try moving this 1 notch at a time to the left or right, and see if it makes any difference to the graininess.
You could also try moving the Camera Colour option. I moved this 1 notch to the right and it made a notable difference. No only did I then have to colour footage in LIquid 7, which saved me hours of rendering time, the PQ looked better on the plasma and on the 32 inch CRT. |
Ian,
I have played both DV and HDV footage via the Sony supplied Component cable( as HDV) and even composite video ( as SD) to both a Phillips 32Pf 9830 Hd ready 32" and a ( little) less "sorted" Samsung SyncMaster 940MW 19" TV/ PC monitor hybrid and in all cases the PQ was very impressive
In all instances the HDV downconvert to DV was on.
I havent touched either the sharpness or colour option ( havent discovered them ....yet)
While no amount of adjustment can redeem a not so well implimented LCD. they do take a bit of tweaking to set up for optimal PQ ( certainly more than CRT or plasma)
Do you mean though that you did
not need to colour correct in Liquid?
