Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 23rd at 11:30pm and include delivery.
Old 20-04-2006, 12:42 PM   #1 (permalink)
Problem with belkin USB capture device
Could someone help me with this problem
i need to capture tv programs using the belkin Hi-Speed USB 2.0 DVD Creator
when i open windows movie maker and select this it wont let me change the settings to PAL and S-Video it keeps on defaulting to NTSC AND Composite
it used to work but not now have uninstalled the drivers etc but still no luck,
it works fine if i connect a video recorder to it using an svideo cable.
any help would be appreciated
thanks
keith
stardock is offline   Reply With Quote
Old 20-04-2006, 2:15 PM   #2 (permalink)
Thanks: Gave 2, Got 6
Hi Keith,
Have you tried using the hardware with the editing software that came with teh unit?? Not sure what you mean by saying that it works by connecting a video recorder to it using S-video?? SO what doesn't work then ??
DigiStuff
DigiStuff is offline   Reply With Quote
Old 20-04-2006, 4:00 PM   #3 (permalink)
thanks for the reply have just sorted the problem it was F-Secure antivirus software when i disabled it it now captures fine
thanks
belkin, capture, device, problem, usb
[IMG] code is Off
