Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 21st at 11:30pm and include delivery.
Old 18-04-2006, 9:09 AM   #1 (permalink)
Merritt's Avatar
Question Using external microphone with 'AV' input?
Please help!!
I take my car on a lot of track days and as I wanted to video it all, I bought a bullet camera kit. The bullet camera comes with a tiny little (powered) microphone and the audio / video connections are made to my camcorder (Panasonic MX350B) via the standard AV cable (i.e yellow phono connector for video and white / red phono connectors for left / right audio).
The microphone supplied with the kit is not up to the job so I am looking for a decent mic to work nicely with the bullet camera.
To record onto my camcorder from the bullet camera, I must put the camcorder in 'playback' mode and then use a record function as if I was recording from another source i.e. a video player. This is important as it prevents me from using a proper 'mic' input on the camcorder.
Problem is that the external mics I have tried come out very quiet on my recordings and im assuming this is because I am trying to use a 'mic' with an AV (or line level) input?
Can someone please tell me what specs I need to be looking for on an external microphone so that the mic will work with a 'line level' av input?
(is it just an impedance issue?)
Steve
Merritt is offline   Reply With Quote
Old 19-04-2006, 3:21 AM   #2 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 463
What you basically need is a small battery powered mic preamp or mixer that can accept a mic input (~5mV) and up the output to line level (~500mV) that can then be accepted by your camcorder. There are loads of these around from the likes of Maplin from about £10 up, but they tend to run on a 12V power input via a 240v mains adapter. I've not managed to find any battery powered units at anything close to a sensible price with a quick search around the internet, but you may have more time & luck.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
Old 19-04-2006, 6:47 AM   #3 (permalink)
Merritt's Avatar
Cheers Mark -
I suspected that was the case so I went to Maplins yesterday afternoon and bought the following:
http://www.maplin.co.uk/Module.aspx?...reamp&doy=19m4
As you say, it runs from a mains adaptor / power supply but I also bought a connector and have taken the 12v power from my bullet cam.
Initial testing is very encouraging - I just need to spend a few hours finding somewhere to put the microphone so that it won't pick up the camcorder motor noise now!
Thanks for the reply.
Steve M
external, input, microphone
[IMG] code is Off
