Cass88,
Sorry, your camcorder is an
analogue vhs-c camcorder which does
not have DV. It is OK but its design was pre digital video and therefore does not shoot Digital video natively.
Only Digital 8 and Mini DV Camcorders ( Consumer/prosumer) feature DV ( firewire) .
The JVC may be said to have "digital effects". They are effects which are applied to its analogue footage which do not "make" footage itself digital
There are a variety of ways your vhs-c footage can be "digitised " but I wont go into that as It is unlikely to be cost effective and as suggested above, will require learning a few new "skills"
I would strongly look at my post re: using a settop DVD recorder to burn a DVD and then getting your video footage off that on a PC for further use .
If you get to that stage and need software and guidance. Just post again!
