| I need a camcorder or else I get the sack...
OK, a slight exageration but I've been reading way more than my employer would probably like me to during work about camcorders which I knew next to nothing about. I now know next to something about them but am held hostage by whatever review I read or forum I land upon. One minute I'm almost at the virtual checkout and the next my list has grown to 5. The problem is that I'm in the same boat as most people that dedicate too much time to researching a new toy. I like to know what I'm buying as I can't stand knowing that for £30 more (or sometimes less) I could have had feature x,y or z even though in my heart of hearts I'm probably never going to use them. I like to know that I've made a relatively informed decision which in turn makes me buy a better than average product (for my money) which in turn makes the enjoyment of the product that little bit better. I once bought a laptop without doing too much research and although it does the job well, I know I would have been happier if I'd just done a little more research and probably opted for another model. Hopefully you are getting my point...
These are essentially my major pre-requisites for camcorder:
It has to be easy to use as the wife will be doing much of the shooting and she has expressed a wish for simplicity. This is an overriding factor.
I'll be mainly shooting whatever my daughter is doing so that covers a myriad of possibilities.
It needs to shoot relatively well in poor'ish light (however, I doubt my acceptance quality is as high as Stephen Spielbergs so it doesn't have to be drop dead good).
I'm leaning towards the MiniDV format but I still love the fact that DVD is universally accepted (almost) and can be put straight into the DVD maching in the living room that my Nan can turn on and use (without any faffing about).
My budget is about £400 (I realise I need to buy equipment after this, carry bag, better battery, discs/tapes etc...).
I prefer the bigger brands (Sony/Canon/Panasonic etc...).
Smaller is better but ultimately I don't want to sacrifice quality.
I had originally opted for the Sony HC96 as this seems to be good at low level lighting conditions, had read a few good reviews and was one of the new kids on the block. Then I thought that £500 was a bit steep so dropped down to £400 and then went for the Sony HC42 but I read a review that it wasn't so good in low level light even though I'd read lots of customer reviews singing it's high praises.
Now I'm stuck not knowing what to do as I don't want to be disapopointed if I go with the HC42.
I've read the very informative review entitled "How to pick the perfect camcorder" but think the the final choices are a little out of my depth.
Any ideas?
