manfrotto are a very good brand.
I use the carbon fibre version of the 055 for stills photograpy.
That setup might be ok but I would be worried about putting a 6kg* head on a tripod with a carrying capacity of only 7kg. Once you have your 150 atop it, this will be exceeded and sure, the thing probably won't fall apart or anything but I really don't think it'll be sturdy enough for good video work.
The 055 legs are manufactured with stills photography in mind.
*does that head really weigh 6kg? Seems doubtful looking at it... in any case, it's aimed more towards stills than video.
