Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 10:30am and include delivery.
Old 16-02-2006, 9:34 PM   #1 (permalink)
Eden_Falls
Posts: n/a
Lightbulb High Definition CCTV
First post here, so please don't flame me
Say if I take a compact HD camcorder that can output a 720p image via analogue component such as the Sony HDR-HC1, what would be stopping me from putting it in a large, heated camera housing and using it as a CCTV camera?
Power could be provided if the HD camcorder was connected to the mains all of the time, and video could be send down 3 coax cables with appropriate phono plugs on the end.
One thing with the zoom though, I presume a button on the camera controls the optical zoom? x12 optical zoom should be plenty for the application required, however the problem is remotely controlling it - would it be possible to 'pop' the zoom hardware switch off and run two wires or something to a controller that could send a voltage up each wire like on one wire if you want to zoom in and another if you want to zoom out?
Please help me by leaving any comments etc that you want to, and as for the monitor (television) its going to be a samsung 50" 1080p one as soon they hit here in the UK, (maybe a1080p camera instead of a 720p one too if moneys available)
Old 16-02-2006, 10:10 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 128, Got 466
Isnt that a rather expensive way of using a camcorder, just shop for a top quality CCTV.
My flickr Pentax K20D/ K10D Sigma 10-20mm/Tamron 70-300mm/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is offline   Reply With Quote
Old 16-02-2006, 10:16 PM   #3 (permalink)
ijd
Thanks: Gave 105, Got 154
more money than sense springs to mind
ijd is offline   Reply With Quote
Old 16-02-2006, 10:18 PM   #4 (permalink)
vonhosen's Avatar
Thanks: Gave 0, Got 16
What are you going to store the images on ?
Any views expressed are mine & mine alone.
vonhosen is offline   Reply With Quote
Old 16-02-2006, 10:26 PM   #5 (permalink)
Eden_Falls
Posts: n/a
I have got an Ati AVIVO graphics card that has component input, so I'll use that and the capture software to record direct to the hard disk and use that as a dvr.
Not THAT expensive when you think about it, a top line sony 480 line single 1/3" CCD Standard Definition costs £300 without the lens, so add another £50for that and it costs £350. HD is only just over twice as much...
Old 16-02-2006, 11:05 PM   #6 (permalink)
Thanks: Gave 19, Got 8
We need more quality CCTV for those porn videos to be leaked
Like Danni Minogue stuff.
Legendary is offline   Reply With Quote
Old 16-02-2006, 11:43 PM   #7 (permalink)
Roy Mallard
Posts: n/a
HC1 is 1080i not 720p
HC1 has a lanc socket that can control zoom and focus remotely
By the way 'legendary' one always feels that the 'CCTV' porn footage of the likes of DM and AT and PH is all staged for publicity, doesn't alter the fact that the rest of it is of unwitting eastern europeans who generally have no choice in the matter. The track marks and cigarette burns kind of spoil the viewing experience for me.
Old 17-02-2006, 1:41 PM   #8 (permalink)
JagoPlasma's Avatar
Thanks: Gave 625, Got 268
Eden, Sony normally have a plug in for remore control of zoom/rec funtions, try looking at accessories for that camera.
also i take it your using it as CCTV to give to the police if a crime is commited? bare in mind that alot of courts/police stations only have facilities for VHS or if your lucky DVD. so you have to think about the end result....
i know for a fact a certain police organization dont accept CCTV unless it is in a usable format to them or "if they want it really badly"
GAMERTAG&PSN: WilmaDicfit
Display's:50PZ80, 42PX60 & Optoma HD65 TV Source:Sky HD WD1TB Audio:SCPT560
Consoles:PS3, XBOX360, Wii
Other Stuff:iPhone 16GB, Canon 450D, Sony HDR-SR12E, Linkstation Live 1TB, WD Mybook 1TB
JagoPlasma is online now   Reply With Quote
cctv, definition, high
[IMG] code is Off
