Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Samsung SMX-C10
Panasonic HDC-SD200
 More...Prices updated November 25th at 3:30am and include delivery.
Old 13-02-2006, 4:36 PM   #1 (permalink)
Thanks: Gave 2, Got 3
Question Any advice to "clean up" VHS to DVD
I have some home videos on VHS. I want to make DVDs of these. I,m considering using me Dvcamcorder to do the conversion, ie VHS to cam via AV input, then firewire from cam to PC. I assume this will work OK.? Any other sugestions?
On PC, is there any way to clean up the signal? Any particular programs good for this?..make it clearer? I realise it won't be "DVD" quality, but maybe improve on contrast/fading from old recordings..
Any advice greatly appreciated
ta
Jai
stormjai is offline   Reply With Quote
Old 13-02-2006, 7:59 PM   #2 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 465
As long as the camcorder does have AV-in (many sold in UK don't ) then this is probably your best option.
A better option may be to get the cleanest possible capture in the first place. To do this you can use an SVHS VCR and therefore use the S-Video connection rather than composite. Also a few of the better JVC SVHS VCR's have a device in them called a time base corrector (TBC) that should help to clean up poor recordings. If you have a good VCR already that does not have a TBC then you can buy a standalone unit, but this is probably more expensive than a new SVHS VCR.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
advice, clean up, dvd, vhs
[IMG] code is Off
