Originally Posted by alogo thanks again. Two questions however:
1) i take you filmed the train on a tripod, and i f that is the case...
2) Does the steadyshot function while you are filming in 16:9
By the way the video rocks! i'll go and buy one as soon as possible! |
The train was filmed on a tripod. I prefer to film, where possible, with a tripod as it looks more professional when screening videos to others, the footage tends to look better on a large screen TV and the tripod tends to improves the PQ as the MPEG encoding does not have to work so hard if the background is static. Of course there are situations when filming handheld is preferable though.
The steadyshot function works with 16:9 and 4:3 modes. Although it is electronic as opposed to optical, its very good and is equally, if not better than my Panasonic DS28 with optical stability. The low light footage was filmed with steadyshot but the camera was being panned a lot, trying to follow the action but the picture is certainly not jerky and panning is quite smooth with horizontal and vertical motion.
