Need to know more about your set up / lack of & budget / lack of
Avoid Pinnacle 10 for HD, its not stable.
Final Cut Express HD is an ok choice, it uses the Apple intermediate codec which can slow down capture depending on the spec of your mac.
Mid range solutions such as Pinnacle Liquid 7 and Sony Vegas Pro have some fans on here, I've tried and tried with Adobe Premiere 1.5.1 and it isn;t great for stability either.
You will need upwards of a gig of ram, as much processing power as you can eat, a dedicated fast 7200rpm hard drive purely for video and a recent 256mb graphics card, the higher the spec the better.
YOu can edit SD on most present editing set ups, but HD will require some money spending. If youare not yet affiliated I would strongly suggest a mac.
