Hi, I know you’re happy now Noah, but I thought I might just add my two pence worth for anyone else looking in… It’s the old chestnut, Ulead DVD Movie Factory 4. It probably doesn’t do everything quite as well as separate programmes instead (I haven’t tried any of the others mentioned), and does more than you need just for MPEG editing, – but as an all-in-one solution, I find it a rather useful and versatile alternative (at only about £25).
It will import MPEGs (VOBs) straight from DVD, or take most types of video files (except MPEG4 – I think you have to get an extra add-on for that), and will also capture from a digital camcorder. It will do “lossless” MPEG editing for basic editing (e.g. cutting and pasting), and will do fades / titles / soundtracks etc.. Editing is obviously limited compared with full NLE programmes (Adobe Premiere Elements, Video Studio, etc.), but I’m assuming that they’d all have to re-encode everything edited as MPEG at the end, losing quality??? And as I say, I don’t know how it compares with Womble or VideoReDo for editing?
If you’ve got an MPEG video, then Movie Factory, like NeroVision and TMPGenc, will author it (do menus, chapters, etc, and put the files together for a compatible DVD) without re-encoding it, and also burn it to disk. If you’ve got any other video file (e.g. DV-AVI), it will encode it to MPEG for authoring, – although I’m led to believe that Canopus Procoder (Express) or TMPGenc are actually better encoders for picture quality (haven’t tried them personally). Horses for courses and all that!!
