Check that your PC has a firewire (aka iLink, DV port, ieee1394) port on it. If not then you can get a firewire card to plug onto the motherboard for under £20 and this should include the cable. If you already have firewire then as already mentioned you can get just the cable for under £10. It is recommended that the cable be a max length of 1.8m
If it is for a desktop PC then you need a 4 pin (cam end) to 6 pin (PC end) cable, or on a laptop it will be 4 pin both ends, but other than that any cable will do the job.
Mark.
