If the camcorder is actually requesting you to use a head cleaning tape then that is what you should do. I doubt it is the start of any problems though, just that the heads need cleaning. Get yourself a good miniDV head cleaning tape and follow the instructions closely and only use it when the cam requests it as they are abrasive and will wear out the heads if used too often.
Mark.
__________________ Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200 |
