Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 8:30am and include delivery.
Old 03-01-2006, 10:31 AM   #1 (permalink)
Thanks: Gave 6, Got 0
Compatable batteries-any issues ?
We treated ourselves to a new digital cam-corder this Xmas, a Panasonic NV-GS150EB. We want to use it on holiday later this month but need a longer recording time than the CGA-DU12 supplied battery gives. The maximum available in the manual is a CGA-DU21 battery. A Panasonic battery is very expensive but I see on E-bay lots listed that are CGA-DU21 COMPATABLE ! and much cheaper.
Are these OK to use ? I have a separate charger so don't need to charge from the cam-corder.
Any advice would be appreciated.
4lbl7
4jbl7 is offline   Reply With Quote
Old 03-01-2006, 10:50 AM   #2 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 463
I've never known a compatable battery cause a problem, ie damage the camcorder, but they are known to not have as good a lifespan as origionals. I would suggest you steer clear of the very cheap ones and go for a seller on eBay with a lot of good feedback. Be aware though that many of these batteries come from Hong Kong etc and may take a fair while to arrive, so leave plenty of time when ordering for it to arrive or you could be going on holiday without it.
I've been useing a compatable battery for around 6 months now in my laptop and it is going strong, holds its charge longer than the origional batter would have and cost about half the price. Just look for a battery with the maximum MiMH (or whatever type it is) rating as this will extend the amount of time the battery can be used for.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
Old 03-01-2006, 2:17 PM   #3 (permalink)
I agree with MarkE19, I have used compatible batteries with my old Panasonic analogue camcorder without problem. I have them also for my Canon DV cam and my Canon digi camera. I would also agree that you need a reputable supplier. I have used the same one for all the time I have used camcorders and feel that I have somewhere to go back to should something go wrong with them. I usually pay around half the price of the standard manufacturers price for a heavier duty battery. I may have been lucky but my "cheaper" batteries actually lasted longer than the Panasonic ones I had. Have a look here for examples.
http://www.keene.co.uk/
ellington
ellington is offline   Reply With Quote
Old 03-01-2006, 3:34 PM   #4 (permalink)
Iain's Avatar
Thanks: Gave 18, Got 9
I second ellington for suggesting keene. I have used them many times without a problem, they have good prices and cater for just about any make and model. Plenty of other goodies to check out on the site too, I was on yesterday just looking for AA Nimh's and came away with them, a wireless cctv kit and a whole host of camera filters to name but some.
This AV habit is getting the better of me
Iain is offline   Reply With Quote
Old 03-01-2006, 4:46 PM   #5 (permalink)
Thanks everyone.
Peace of mind restored
4jbl7
batteriesany, compatable, issues
[IMG] code is Off
