Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 8:30am and include delivery.
Old 02-01-2006, 5:39 PM   #1 (permalink)
MJW
MJW's Avatar
Question Transferring VHS to DVD using PC
I have some old VHS tapes which I need to transfer to DVD but I've been having some problems. I think I have all the right equipment, here goes :
Video source - an old Panasonic NV-SJ206 VCR
It only has a SCART in/out so I've bought a little SCART adapter that has left/right audio out as well as S-video and composite video out
PC - The graphics card is a Radeon X800 XT Platinum edition which has video in / out and an adapter that plugs into it allowing you connect either S-video or composite video input.
Software - I've tried three bits of software : Windows Movie Maker, Virtual VCR and Virtual Dub.
The problem is I cannot get a video signal to appear in the preview window and therefore cannot record any footage. I suspected it may have been because the VCR output a PAL signal, so I flicked a DIP switch on the graphics card to change it from NTSC to PAL but still no joy.
Can anyone please help ?
MJW is offline   Reply With Quote
Old 02-01-2006, 6:05 PM   #2 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 463
Scart plugs are directional. The adapter you have may be designed to only output the signal through the scart rather than the phono/S-Video sockets. What you probably need to do is get a switchable adapter so the signal can go in either direction - something like This. Also make sure you use the composite (phono video) connection rather than the S-Video if the VCR is VHS or you will only get a black & white picture. The S-Video connection will only work with an SVHS VCR.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
Old 02-01-2006, 6:35 PM   #3 (permalink)
Does your camcorder allow analog input signals?
If not by default - have you enabled that function?
Not all old camcorders allow analog input signals but they can normally be enabled.
sirugo is offline   Reply With Quote
Old 02-01-2006, 7:48 PM   #4 (permalink)
MJW
MJW's Avatar
Hi thanks for the replies. There's no camcorder involved just an old VCR, some VHS tapes and my PC. The scart adapter is switchable for input/output and I set it to output from the VCR
dvd, transferring, vhs
[IMG] code is Off
