Thanks for your replies,
I will try a direct connection to the TV shortly and post back.
The laptop I am using I have used before but with a sony cam. It is fairly new and good specs for a laptop. Toshiba Qosmio G20
Technology type : Intel® Pentium® M Processor 760, Intel® PRO/Wireless 2200BG network connection and Intel® 915PM Express chipset
clock speed : 2.0 GHz
front side bus : 533 MHz
2nd level cache : 2 MB
Operating system Windows® XP Media Center Edition
System memory standard : 1,024 (512 + 512) MB
maximum expandability : 2,048 MB
technology : DDR2 RAM
Hard disk capacity : 160 (80 + 80) GB
DVD Super Multi drive (Double Layer) compatibility : CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
maximum speed : Read: 24x CD-ROM, 8x DVD-ROM/ Write: 24x CD-R, 10x CD-RW, 8x DVD-R, 4x DVD-RW, 8x DVD+R, 2.4x DVD+R(Double Layer), 4x DVD+RW, 3x DVD-RAM
type : DVD Super Multi drive (Double Layer)
Display size : 17 "
type : Toshiba TruBrite WXGA+ TFT display
Graphics adaptor manufacturer : NVIDIA®
type : GeForce™ Go 6600
memory : 128 MB
memory type : DDR SDRAM
connected bus : PCI Express x16
Internal video modes resolution : 1,440 x 900
maximum number of colours : 65,536
Max External Video Modes Max Resolution : 2,048 x 1,536
Max Colours : 16.7 Million
Max Refresh Rate : 100 Hz
Non-interlaced resolution with max refresh rate : 1,600 x 1,200
BIOS ACPI : Yes
System Management BIOS : 2.3
Battery technology : lithium-ion
maximum life : up to 2:00 hours
AC adaptor input voltage : autosensing AC adapter (100/240 V) for worldwide usage
Interfaces 1 x headphone
1 x DC-in
1 x line-in
1 x external monitor
1 x RJ-11
1 x RJ-45
1 x i.LINK® (IEEE 1394)
4 x USB 2.0
1 x Monitor-in (composite video and L+R audio)
1 x TV-antenna
1 x S-Video-in
1 x TV-out (s-video, Component-out))
1 x 5-in-1 Bridge Media slot (supports SD™ Card, Memory Stick®, Memory Stick Pro™, MultiMedia Card™, xD-Picture Card™)
Expansion 1 x PC Card slot for 1 Type II card
2 x memory slots (0 available)
1 x ExpressCard slot
TV tuner manufacturer : Toshiba
type : integrated TV tuner
tv standard : PAL
Wireless communication Compliancy : Wi-Fi™
Network Support : 802.11b/g
Wireless Technology : Wireless LAN (802.11b/g dual-mode integrated network support)
Wireless Technology : Bluetooth™
Wired communication topology : Ethernet LAN
speed : 10/100 Base-TX
topology : international V.90 modem (V.92 ready)
speed : 56 Kbps data and V.92 data fax
Sound system supported audio format : 16-bit stereo
speakers : built-in Harman Kardon® stereo speakers
