Um - "he saved it as NTSC" ?? - or he used an NTSC camera - only one maybe two cameras give you a choice and I believe you have to set them before you start. Any way yes you will be able to edit it on your PC because your computer is neither PAL or NTSC, you can import either to a computer and edit it. The problem will be when you burn a DVD and then try to watch it on a TV - Some systems in the UK may play it (at reduced quality) - some will only play it in black and white - some won't play it at all
