| VOB Converter codec question
i need to find the best way to convert VOB files direct from dvd to avi so i can edit them.
i have a copy of winavi converter which is supposed to do this but i don't think i have the right codec as i can't view the imported avi in windows media player, the audio is there just a black screen. I haven't tried to import and edit this yet as i believe that if windows media player won't play it then something isn't right.
this is to access material on my home made dvd's not bought ones so there is no issue about removing macrovision etc.
i use ulead movie studio 9 which has the ability to lift straight from a dvd disk however it won't read some of my disks, which is strange because they play ok.
bottom line.
whats the best software to convert VOB's to avi and what settings or codec do i need?
thanks
