The main control you need to avoid motion blur is a camcorder with an adjustable shutter speed, all of the panasonic miniDV camcorders have this even the cheapies.
There are a couple of route that, if you had money to spend, might be worth exploring:
1: HD camcorders, would give you much higher quality individual frames to work from, capable of reasonbale sized print outs, miniDV won't really. Fine for on screen, not good on paper.
Start from £1500
2: Panasonics AVX200, not out quite yet, gives you HD (though not to the maximum standard possible) but interesting does give you a variable frame rate as well as a variable shutter.
This means you could take a lot more individual frames over the duration of the swing than with a fixed 25fps camera.
Down side is, well the cost. Don't expect much change from £4k.
In breif conclusion, a £230 MINIDV panasonic will do the best budget job, the more you spend the more scope you have, but it goes to big money.
As you are using a faster shutter (probably 1/500th second or maybe even higher) you will need plenty of light, so it may be worth pricing a powerful mains or portable unit.
