Firewire problem
Old 15-08-2005, 8:09 PM   #1
RobPowell
Posts: n/a
Firewire problem
Hi there
I just built a new system and firewire seems to be working okay (although no way to test), but when I hook up my mv600i to it, the PC won't detect it.
The camcorder shows as "DV In" so that "sees" the connection, but the PC just won't connect.
Can anyone suggest a course of action?
Old 15-08-2005, 9:42 PM   #2
7,335, Level: 20
Points: 7,335, Level: 20 Points: 7,335, Level: 20 Points: 7,335, Level: 20
Thanks: Gave 2, Got 6
What exactly won't connect?? If it's editing software then please let us know which one and version.
We just all need a little more information to be able to help you out!
Cheers for now
DigiStuff
Old 15-08-2005, 10:09 PM   #3
RobPowell
Posts: n/a
Thanks for the reply! okay I am using pinnacle studio 9 patched up fully, but I don't think that's really the problem.
On my old system windows would detect when I plugged the camcorder in and switched on, this one doesn't even do that!
or do you think it's a problem with pinnacle?
Old 15-08-2005, 11:25 PM   #4
Roy Mallard
Posts: n/a
not used pinnacle 9, however I have had problems with canons in the past, if you have the option in the 'settings' menu in the capture window then select the most basic version of device control that you can (in fact just check that you have selected PAL for the UK or NTSC for the US)
If still no dice then you have to into the 'start' menu on windows, go to 'control panel' , go into 'system' , go into 'hardware', go into 'device manager' look for 'IEEE1394 Bus host Controllers' (it is likely there will be a 'hazard' sign next to it) click to expand, highlight the approporate device, left click then let windows find a driver for you (you may want to try this offline first)
Powered by
 Latest popular product prices
Kodak PlaySport Zx5
7 prices from
 £79.99 Click to show/hide the offers
Sony DCR-SX45E
3 prices from
 £189.99 Click to show/hide the offers
Toshiba Camileo H30
1 price
 £107.00 Click to show/hide the offers
Panasonic SDR-S70
7 prices from
 £116.00 Click to show/hide the offers
Panasonic HX-DC1
7 prices from
 £123.95 Click to show/hide the offers
Samsung SMX-F50BN
4 prices from
 £119.99 Click to show/hide the offers
JVC GZ-HM30
7 prices from
 £144.99 Click to show/hide the offers
Sony DCR-SX21E
2 prices from
 £149.99 Click to show/hide the offers
 Updated February 10th at 11:30pm. Prices include delivery.
[IMG] code is Off
