Hi Mark,no not at all,i was kinda hoping it would be you who would reply,as i have noticed you reply to a lot of posts, have a broad spectrum of knowledge and seem to know what you are talking about.I understand what you are saying about being able to control the camera through the screen ,I just expected the camera to carry on playing ,after i have clicked the" stop capture"button to save you having to click the "play" button again. ,but any way ,on to more important things.In your first reply you say,save the time line as an avi file ,then load it into "mydvd" to be able to burn it to disc.Does "mydvd"then convert the avi files again into mpeg2 files in the process of burning.I am a bit confused because i read somewhere that avi files are low quality compared to mpeg2 files,so if the movie is saved as an avi file does this mean "mydvd" is recieving a lower quality version of the movie,which infers a drop in picture quality.If this is the case ,could the time line be saved as a mpeg2 file then load it into "mydvd",or am i worrying for nothing.
One other thing i am unsure about is,right at the beginning of the capture process,when wmm2 asks what format i want to save the files as ,ie .wmv or avi,which should i choose t avoid unecessary conversions later on.One final thing is how do i determine/match which recording speed to use when doing the final burn to disc,ie to be compatable with the disc speed recording capabilties and the pc drive unit recoding speeds.
Thanks again,
Paul
