Not done it, but see no reason why you can't!
Most camcorders have a dedicated cable for the AV output - small jack or din type plug to yellow, red & white phono plugs. Just connect this to the senders composite video & stereo audio inputs and away you go. If the sender only has a scart input then just use a phono to scart adapter, just make sure it is an adapter wired for phono>scart direction rather than scart>phono as they are directional!
Mark.
__________________ Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200 |
