Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 22nd at 3:30pm and include delivery.
Old 26-04-2005, 8:47 PM   #1 (permalink)
creating dvd via ulead MF3-problem
Guys another day, another footage another dvd.....
i got 1hr 23min of footage which i saved on to my PC as a avi file (17.5G) i used ulead to add file and the blue bar at the bottom of the screen which represents space, was full!
it says "5.61 (5.22) GB/ 1hr 23min 23sec" question 1- what does this mean?
I then saved the same footage as a 2.1mbps pal file(wmv) vai windows movie maker now sized as 1.17GB
I then add it to ulead and still get:"5.61 (5.22) GB/ 1hr 23min 23sec"
Question 2, as i made the file much smaller why cant i still fit it on to a dvd?
Please can anyone help...... i have been here before but i gave up then... but i'm back.
ketank is offline   Reply With Quote
Old 26-04-2005, 9:07 PM   #2 (permalink)
Thanks: Gave 0, Got 2
5.61 is the size of your file in DVD disc makers terms (they use different Gbs than the rest of computer makers/users) this will give you a computer file size of 5.22 Gb so that is what the first line is telling you.
If you produced a .wmv file and then took it back into your DVD authoring programme and told it to produce a DVD it will convert your file back into a standard mpeg-2 file for burning to a 'standard' spec DVD so that it will play on your stand alone DVD player - so your back to the same size file. If you just burn a .wmv file to a DVD it will not play on most standalone DVD players.
You should be able to burn your 1 hour 23 mins video to a 4.7 (4.37) DVD by simply changing the bitrate - if you drop it to around 60000kbps it should fit no problem. I don't know where that setting is in MF3 but your manual should tell you - if not maybe someone who does will be along shortly.
My Videostudio help website
Brian110507 is offline   Reply With Quote
Old 27-04-2005, 10:31 AM   #3 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 463
To change the length of video able to be written to a DVD in MF£:
Open MF3
Click on the cogg at the bottom left of the screen (settings)
On the new window click on 'Change MPEG settings'
Select either 'Good quality (Approx 90 minutes per DVD)' or 'Customize' and set to 'Variable'
HTH,
Mark.
ps, on a PC 1Gb = 1024Mb - on a DVD 1gb = 1000Mb, that is why the difference in size is displayed. Notice the difference of 1Gb or 1gb!!!
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
creating, dvd, mf3problem, ulead
[IMG] code is Off
