Originally Posted by laser Pinnacle Studio 8 or 9 and Ulead DVDMovie Factory will let you import MPEG2 files and then allow you to edit and create a DVD from multiple clips.
Note: it only works with mpeg2 files which have a .mpg file extension. If the mpeg2 files have been encoded for DVD as .vob files, it won't work. Hence you can't capture and edit prerecorded or material already on DVD.
There maybe other software applications which would allow you to edit MPEG2 .vob files. You could try downloading the trial version of TMPGEnc DVD Author. |
Just remane the vob files to mpg then DVD MOviefacotry will accept them, however DVD MOvie facotry is no good for AC3 / dolby digital encoded DVD recordings unless there is a plug in I don't know about ??
