Depends on what equipment you have at your disposal.
At its simplest, you make a copy from (say) your camcorder to (say) VHS, and only copy the bits you want to keep.
Or, if you have a DVD recorder with a Hard Disk, you copy from your camcorder onto the hard disk, use the DVD recorder's editing features to cut the bits you don't want and then burn a DVD.
Or you load the whole thing onto your PC's hard disk, then use editing software to do fades, add soundtracks and titles, special effects........... and then burn a DVD.
etc......
What you don't do is take a sharp knife or scissors to your tapes.
