| IEEE1394 Link .. PC min spec
I'm glad to see that some people can get this working. I too am having problems stuff from my NVGS11EB through firewire and was wondering if the firewire card and cable I bought from Novatech for about £20 may have been the cause.
Is there a min spec of PC that you need to be able to get it working. I currently have a AMD 1100 Duron, 1Gb RAM, 80Gb disk (with loads freed up!), 128Mb nVidia MX440-SE graphics card, Windows XP Pro SP2.
Do I need to update any software, drivers et al. The mobo I have will handle up to an XP2600 working on a 266Mhz core, and have been considering for a while about upgrading it with something more beefy as the wife also uses it for her business!
Any advice would be welcome. I believe that the firewire technology does give you the best quality downloads from your camcorder, but to me, is a pig getting it working!!
ScrozUK
