Thanks for that, tripod weighs about as much as a small child, so I don't think it could be the "lightweight" version -
++ yes agree the lens is zoom max 300 (35mm equiv), but I also have a 1.6x Nikon extender, which I've use on Venus and moon, recently. However, this is a 35-200 Tokina Zoom and it's about 2stops darker than a 200mm f/3.5 Hoya - when set to the same aperture. I presume the internal glass design somehow loses light.
However, for moon-shots (about a year ago when it came particularly close)... I used the Hoya and it was really BRIGHT.
If I said I'd used the Tokina Zoom, this will have been wrong.... I didn't have it then.
You probably guessed I don't do wildlife, as you will know that lens is a bit short. The tokina is a tiny bit soft compared with the non-zoom Hoya - only to be expected....but being able to "frame the shot" means the zoom is the long-choice. The Tokina that has a dedicated fitting for the Manfrotto, which I made..
