Go Back   AVForums.com > Home Electronics > Camcorders and Video Editing
Today's price checkPowered by
Panasonic SDR-S26
Sony HDR-XR520VE 240GB
Canon Legria FS200
Panasonic HDC-SD10
Panasonic SDR-S26
Canon Legria FS200
Panasonic HDC-SD10
Sony DCR-SR37E 60GB
JVC GZ-MG630 60GB
Sanyo Xacti VPC-CG10
JVC GZ-MS120
Panasonic HDC-SD200
Samsung SMX-C10
 More...Prices updated November 24th at 12:30am and include delivery.
Old 25-10-2004, 5:20 PM   #1 (permalink)
Advice please
I have an analogue Panasonic S-vhsc camcorder which lacks any USB or firewire connectivity. I have quite a lot of recordings on svhsc I would like to convert to DVD so I can reuse the tapes. I also have an extensive collection of VHS material I would like to copy to DVD too - mostly old movies taped off the BBC etc.
My wife is expecting and I plan to record plenty of baby video etc but have a dilemma. Should I buy a new budget Dv camcorder with analogue inputs to enable me to route a feed from my old camcorder through the new one to the USB connection on my laptop or should I just buy one of those £100 video capture devices to run between the camcorder/home VHS and the computer with its DVD-R drive?
I am quite happy with the quality of my existing camcorder and would rather spend £100 on a video capture device than £350 on a new camcorder especially with a baby on the way.
I'd welcome advice from the experts on here though.
Many thanks,
Saxon
Saxon is offline   Reply With Quote
Old 25-10-2004, 5:42 PM   #2 (permalink)
Conspicuous Member
Thanks: Gave 15, Got 465
Well if you are happy with the quality you get from your current camcorder then there really is no need to replace it. You would get better quality from a DV cam, but more than likely it would be poor for indoor use without additional lighting.
So what are your options?
Basically you want to ignore the USB ports as although you can get analogue devices that will connect via USB they are often low quaity and can cause lip sync errors.
The best way to connect an analogue converter to a PC/laptop is via firewire. Even on a laptop you can add a firewire port for around £20-£30(ish!). I would then advise one of the Canopus ADVC converters. They have differing features where some can convert back to analogue where some can't etc. Do a bit of reasurch to find out if you want any of the additional features, but they can all be bought from www.sirentechnology.co.uk amoungst other places.
ADVC100 - £193.88 (A/D & D/A)
ADVC55 - £151.58 (A/D only)
ADVC300 - £410.08 (A/D & D/A and has TBC that will help to improve the PQ by a fair amount)
I have never used these devices as I have onboard analogue & digital inputs on my PC capture card. But everybody that has reported on these seems to be very happy with the results.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline   Reply With Quote
Old 25-10-2004, 7:13 PM   #3 (permalink)
vonhosen's Avatar
Thanks: Gave 0, Got 16
I use an ADVC-100 , it's a great reliable product & easy to use
vonhosen is offline   Reply With Quote
Old 26-10-2004, 2:30 PM   #4 (permalink)
Many thanks
Thanks for the advice guys looks like a £150 device is the way to go.
Appreciate the help.
Thanks,
Saxon
advice
[IMG] code is Off
