Thanks, Carlito, that sounds like a potential solution...however, my computer knowledge is not that hot, and I'm really reluctant to go fiddling around with my motherboard settings...!! Could this be the same problem I'm experiencing? I have outputted video analoguely before via my ancient miro DC10 video card, on the same computer set up, and that has been fine... fiddling around with motherboard settings seems an unlikely thing to have to do...grrr....
By the way, my thoughts before reading your reply were as follows:
I have now been back to the shop and exchanged the camcorder for another (due to an unrelated fault on my original model), and exchanged the firewire cable.
The exact same fault still persists, however, but at least now I know it isn't:
a). a dodgy camcorder
b). a dodgy cable
c). dodgy software (I've tried various different software packages and all have the same result).
Sooooo, where does that leave me?
Well, I'm sure my computer's spec/memory requirements are high enough to cope, so that leaves me with...um...not a lot really. Therefore, it must be a dodgy firewire port in my computer! What else could it be?
The firewire socket is on my sound card... what's my best course of action? Just purchase another firewire card? how much are they? are there any different types? whats the cheapest? can i stick it in anywhere in my computer? is that easy to do? or should i try and get my existing firewire port looked at?
hmm...
Advice please from those in the know!!
