1. I wouldn't of thought so, minidv is THE format nowadays.
3a. Canon are notoriously poor in shooting in low light.
3b. A HDD recorder is not ideal for editing and will NEVER match the capabilties of a PC. So you'll soon be on the PC to do some serious editing and DVD authoring. And it's here that you can maintain the original quality of the tape and after editing, copy it straight back to tape with NO quality loss what so ever and have an excellent master tape.
Remember, as soon as you convert it to DVD you will lose some quality due to the compression in th empeg2 foramt.
So DV in on a camcorder is a MUST.
3c. Useful if you want to covert old tapes to digital so the cam would act as a 'capture device' but here your HDD (DVD too?) recorder would suffice as you're dealing with low quality analogue.
4. Don't let something as trivial as batteries restrict you to one brand.
Also have a look at some of the Panasonics and Sony and also consider 3CCD cameras, which are a lot cheaper these days.
5. 'True 16:9 widescreen' recording, although the jury's still out on this one!
3.5" LCD Screen.
Stills capabilty.
Cost of solid state media, Memory sticks, SD cards etc.
Manual controls, i.e. manual focus ring.
Top loading tape, essential if you use a tripod.
Optical image stabiliser.
Smaller optical zoom range.
BTW, I'm in the market too and have short listed teh Canon 3xi, 25xi, Sony HC1000 and Panasonic GS 400.
