no, you are wrong.
both formats give you 720 vertical lines, miniDV gives you over 500 horizontal, which DVDcam aint gonna beat, and besides the AVI compression is nowhere near as lossy as MPEG2.
You'll be stuc with crap software ptions, expensive discs that only give you half the recording time of dv cassettes.
The camera is a lot bigger, the format less stable.
the sole benefit of the format is that you can play it through SOME dvd players, great if you share your (UNEDITED) footage with friends/family, provided their DVD player will play your discs, totally useless otherwise.
miniDV cams come with AV cables to play back on any tv with scart or phono & in some cases Svideo in.
miniDV cameras cost less feature for feature
miniDV tapes cost a lot less, run for longer and can be reused
miniDv cameras are more compact
miniDV cameras will work with a wider range of software
miniDV format is an established widely used format which will continue to be used for quite some time, have you looked at the DVD minefield?
image quality (resolution & compression standards) is higher on miniDV
if you buy a DVD camcorder EVERYBODY on this forum will laugh at you
at school sports days, other parents will laugh at you
Your partner Jane will be embarrassed to be seen with you when you swing though the trees with your DVD cam.
In fact the DVD cam is so big and heavy most vines will simply snap, and then you'll look a bit silly
You'll no longer be king of the jungle, that title will go to the man a few trees down the grove with the miniDV camcorder
There is a recent history of dvdcam owners being found in shallow graves in Epping Forest if you get my drift...
I'll be watching!.
Be safe.
