OK the most important thing is to connect the cam and power it on before starting the capture/editing software. As long as you do it this way you should have no problems with the cam being picked up.
But to start from the very beginning it should ideally be done as follows:
PC turned off
plug cam via firewire to PC
power on cam
boot PC
start editing software.
HTH,
Mark.
__________________ Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200 |
