Hi Beejaycee,
Right I'll explain as best I can.
Firstly, I recorded a program from my cable box directly onto my DVD Recorder (Phillips 880). This was recorded onto a DVD+RW
I then fire up Ulead VideoStudio 7 trial version on my PC.
I insert the DVD+RW with the program recorded on it into the DVD Rom drive. (When Power DVD loads up and I watch this program the audio is present)
I then click on capture and capture settings.
I then click on Capture video.
Now from here it appears to capture the video and split it into scenes.
I then highlight all the scenes and click finish.
This then loads all the data up into the liberay. When I click on one of the thumbnails it loads up into the previw screen.
I then click play and it does so without any audio what so ever.
Now I have gone through the settings a number of times and the audio seems to be set correctly.
This may not be relevant.
When I click on the options panel (in Capture settings) there are three choices.
1 Capture Video
2 Video Settings
3 Audio settings
If I click on 3 the audio settings look correct.
But if I click Capture video (I think its this one) a little box opens with 3 boxes to tick. The one on the far left says something about captureing audio. This box is ticked but is not highlighted, which means I can't tick this or untick it.
When I click on the Timeline mode I managed to separate the audio track from the video. When I click play for there is no sound even though it apppears to be playing something.
The audio track is the same duration as the video.
Does this make a bit more sense
