Not a problem I've ever had, so I can only hazard a guess, random noise problems in other audio circles can often be traced to loose or dirty connections, or interference being picked up from some local source. Maybe you should try another firewire cable just to check, maybe a slightly more expensive one with better shielding also see what else is happening in your vicinity (TV ??, Large audio speaker ??, fridge running ??, electric drill ??? vacuum cleaner etc. etc. )
Wouldn't of thought it had anything to do with it being a trial copy
Sorry can't be more positive
