| Re: Canon HD cam is more popular than Sony HD cam ?
Thanks, Andrew. I thought about that too.
A decent Sony model cost $750 at Costco while a very good Canon (like HF200) can be found on line for a mere $475.
The Sony model has three unique features that the competition do not have: excellent stabilizer, slow smooth motion capture, lower light capabilit (indoor).
The first two I think there are some software to create in the post processing part-I am not sure how effective it works. However, I think I am stuck with the low light.
I also read that some reviewers exaggerate the low light on the Canon as they are mostly perfectionist. The actual result is very acceptable if you set the shutter knob correctly.
